96 Johnson 40hp water pump
big_jack
"Guys,after only one summer on
"Guys,after only one summer on a brand new water pump,I noticed that it was not peeing correctly.
I took it apart and found the plastic impeller key(cam)
was melted and in pieces. Is this a common problem
with the plastic or did I install it wrong? Thanks!"
"There is no reason for the ke
"There is no reason for the key to fail as it locks in to the impleller bose and driveshaft and doesnt move, have a good look at everything else."
"I motor through alot of river
"I motor through alot of river sand,maybe the pump filled with sand and sheared the plastic cam. I was wondering if anyone else had this same problem, thanks"
