Jeff Austin
Hello,
I have a 1996 40 HP Johnson TLEDS. It came with a new fuel pump in an OM box 438557 23-A-1L.
I removed the VRO from the front of the motor on the port side of the two carburetors. Toward the stern on the port side, I mounted the new regular pump with two screws and it's gasket over the pulse hole on the engine. (which I unplugged on the engine) In addition, I then proceeded to run the pulse hose (inboard pump connection) to the pulse port that the VRO was using. This pulse port is located just to port side of the lower portion of the bottom carburetor and has a pulse limiter screwed into it.
So my pump has two (2) pulse connections that seem quite far apart.
Is this correct?
thanx...L8r...jeff
Is this correct?
thanx...L8r...jeff
