aquasport200
"I have a 96 150HP Oceanrunner
"I have a 96 150HP Oceanrunner, This is an OIS Looper 60, I tested Stator using a Static test with Ohms Meter to the brown wires and received no output, also done a cranking test on those wires using a volts meter and no output, pulled flywheel and Stator has this Thick Clear Material that has leaked down around crank shaft below stator.. Question; Is Stator Bad? and what cause Stator to melt down like that?"
