geaux_fishin
"I've got an issue with my
"I've got an issue with my 96 Johnson 130 (J130TLEDM). At low idle the engine will stall but will crank right back up. Runs fine above idle all the way to WOT (5600 rpms). Priming bulb does not help at idle. Additionally, the number 1 and 2 cylinders (starboard side) are hot to the touch. Could this be an issue with the oil side of the VRO pump (running lean) and could they be related? Here's what I've checked so far: Compression is 130 in all 4 cylinders. Spark is good. No air leaks in fuel lines. Recently synchronized carbs and throttle linkages. Just changed fuel/water separator filter as well. Any help is appreciated."
