karmadog62
Greetings!
I have a 1996 Evinrude Four Stroke 9.9 hp outboard that runs perfectly for 20 minutes and then acts like it's running out of fuel or getting erratic spark. Here's a video https://youtu.be/uWYP8zWlPCs.
I've replaced ALL electronics, including stator and coil. I've rebuilt the carb, new thermostat and plugs, new impeller, new hoses, new fuel bulb, connectors and hoses, cleaned all electrical connections, and still the engine craps out after twenty minutes.
I've tried squeezing the bulb, nogo. It's pissing good water flow. I'm at a loss!!!
I put the motor in a barrel and ran it in gear for an hour at medium rpms and it never failed. But when I put it on my boat, it fails within twenty minutes every time. If it rests for five minutes, it will start up and run for few more minutes. The longer it rests, the longer it will run, so I suspect a heat related issue.
How do I troubleshoot this?
Thanks,
Mark in Leander, Tx.
Thanks,
