96 Evinrude 15 leaking water from shift rod??
Funny thing is was running it in a tub that didn't flood the water pump housing. No water came from the weep hole. I dunno cant figure how the waters getting out the shift shaft on the lower unit. It cold water that has not gone through the motor.
You will have to post a picture on what you are seeing.----------Is water in the tub well above the joint of the lower unit and exhaust housing ?-----------Verbal descriptions can be very vague at best.----------The shift shaft goes through a seal into the oil in the lower unit.It is not connected to a supply of water anywhere.
