96 ERude 60 oil alarm question
backerdown
"Hey fella's
I removed
"Hey fella's
I removed the VRO pump and disconnected the plugs from the tank to the engine, but I am getting a oil light on my monitor gauge, and a buzzer that goes off after about 5 minutes of engine operation for a few seconds and then I don't hear it the rest of the trip.
Is there a step I missed to disconect the monitor from the engine?
and if that is the case, where is that plug located and what wire config. am I looking for?
Thank you Very much.
Dave Marshall"
Are you getting the low oil or
Are you getting the low oil or no oil indicator. The low oil is the sensor on the oil tank. The no oil is the sensor on the VRO Pump.
Did you disconnect that plug?
"Chris,
Thanks for the res
"Chris,
Thanks for the responce.
The No oil light is illumanated on the system monitor gauge and I disconnected only the plug from the tank to the engine, I take it there is another connection at the VRO that I need to disconnect. Could you tell me what color those wires are that I need to un-plug and are they ON the VRO it self?
Dave Marshall"
