I had a problem with my Mercury would only run at full speed if I pumped the primer bulb on the engine. Pulled and cleaned the carb,it did same thing . Pulled the carb again and checked the high speed jet. I ran a tip cleaner in it to check for obstruction. Reinstalled and ran again idles good starts fine but when I try to get on top sputters bad .once I get it on top it ran fine at full throttle,but dies if you let off the gas.
