96 225, Tips on getting pinion off shaft....
oldschoolnc
Hello, I got the nut loose but cant find a way to get the pinion off. The last one I did seems to have had a thicker nut, and as i turned the driveshaft the nut pressed against the clutch dog and popped the pinion off the shaft. This one seems to have a thinner nut and it comes all the way off b4 putting pressure on shaft. Oh and first one was a counter rotating unit, This one is RH... not sure if it matters....... Any help will be appreciated.
Put the nut back on to protect the threads.----Use a screwdriver or other tapered device between the clutch dog and nut.----Give the propshaft a hefty bump.
