piercer808
Bottom-right carb keeps backfiring. I recently rebuild all carbs, and set the floats to level with the edge of the bowls (when holding the bowl upside down). For this particular carb, I adjusted the float even lower to ensure that it wasn't flooding out. Even tested the float valve by removing the bowl while leaving the fuel line connected, and pumping the prime bulb -- no fuel overflowed over the edge of the bowl. Even applied gasket sealer to the bowl gasket to make sure that no fuel was leaking around the gasket and into the rest of the carb.
Any ideas or suggestions? Thanks!
