I suspect that black plastic piece on the shift rod is not adjusted correctly. Back off on the clamp bolt and see if that does it.
Jeff
Did you rotate the shifter rod when the LU was out? It's screwed in and is rotated for adjustment. Only way to adjust it is to drop the lower unit again. Sorry.
Jeff
