L
lancestapp
Guest
" I have a 15 hp Johnson. I
" I have a 15 hp Johnson. I prime it up pull the choke and it usually starts fine. If you try to take off before it has run for a while it will often die. I guess this is not that abnormal for an outboard. But if I run it a mile or two and shut if off to fish a while I have to go through the procedure again. Pump the bulb, full choke and let it run for a while. Then when I take off in gear it acts like it runs out of fuel and I may have to choke it to get it going again. After you get moving well it runs great at all speeds until you shut it off and it cools down. Bulb pumps up well. Always runs great after you finally get it going. Any Ideas? "
