Good evening all,
First time posting, I’m at my wits end with this one.
Got a decent deal on this 95 force 90hp a coupe of weeks ago thinking I could get it running like the several other engines I’ve had the last couple years. Little did I know this one would give me a run for my money. Info below with some of the steps taken.
Brought home after compression check (130psi on all 3) and hooked to battery and fuel. Found wiring diagram and wired in an ignition to start it on the stand. Engine turned over and fired up every 2-3 try’s on cranking it. After several attempts and some extremely loud backfires out the exhaust I decided to clean the carbs up. Torn all 3 down soaked in diesel for 3 days, cleaned up with compressed air and carb cleaner. A couple ports were clogged but now are free. (Side note, never seen a carb with 3 external ports for the jetting). New float needles and reassembled. Reset AF screw to 1 turn and the thing didn’t even try to fire. Back out until it would fire up at 3 turns out and played with the adjustment with no improvement back down to 1 turn. Checked spark, jusm
