I have a 95 4.3lx Mercruiser.
I replaced intake Manifold along with new Carb. Intake Manifold had a 9 inch crack. It had rain water on the pistons along with the Carb body rusted and frozen.
Then when I went to start it I noticed the flywheel ring gear damage. The PO kept trying to start it with Hydraulic lock and chewed up flywheel.
So I replaced the Flywheel ring gear.
Yesterday had it all back together and tried to start and it. Starter turns it over and then the starter makes a load clunk.
I stopped let it sit for a min and then try again it starts to turn then clunk.
I tried three attempts and then closed it up. Just needed a break to stop and think about the Issues.
I have not messed with it just digging into Mercruiser Maint Manual and forums to get a clue.
I have read a few post about starter not engine into flywheel and that makes senses. AFTER MARKET STARTER.
I guess that seems to easy, but it might be it.
The other question I have, if my Timing is off could I have some early detonation?
At one point i did see a puff of smoke out of Carb.
One other area of concern I have, when I pulled the motor a noticed the PO had broken a starter mount hole.
They welded the mount hole (STARBOARD SIDE) and starter mounts just need to add washers. Not sure if starter might be pulling itself a away from flywheel?
I will need to investigate this as a possible issue.
Right now just brain storming any inputs would be appreciated.
FYI: I have removed Manifolds and pressure tested and no leak. Plus at this point I have no water going through motor.
Thanks....
Thanks....
