Hello and thank you has anyone who tries to help. I have a 1994 Yamaha 150 outboard that began overheating. A little backstory first, I've had this boat for about 4 months and it has always ran perfectly until a couple weeks ago when my lower unit gave out and I had to limp it back to the dock. I found another used lower unit that I was able to purchase. Being a dummy and not thinking to look over the water pump parts I threw that lower unit on to my motor and cranked it up. Once running it took about 25 or 30 seconds to start peeing and then in less than 2 minutes the water coming out of The Tell Tale what's steaming and too hot to touch. I immediately shut it down as soon as that started and pulled the lower unit back off. Once I got the housing off of the impeller I saw where are the rubber on the impeller had been scored up like it was run dry for a short amount of time. I ordered a new water pump kit and replace the impeller, and the base plate in gasket. Once it was all back together I fired it up and the same thing is happening. Once again I pulled off the lower unit this time to find nothing is wrong with the impeller and everything appears to be working fine. I pulled off the water jackets and they were all very clean which came as no surprise because supposedly this motor was completely rebuilt less than five years ago. I also bought two new thermostats and replace them which make no difference in this issue. I'm hoping someone can give me some advice, maybe something I'm overlooking so I can get this situated get back on the water. I should also note that there is steam or white smoke coming out of the vents about the prop, and it's a lot more then I've ever seen in the past. The other thing I want to mention is that the Woodruff key appeared to be filed down a little bit by whoever worked on it last, and I was unable to remove it. When putting the impeller on to the key it seems to fit on properly but I am unsure if there's any possibility Indian color can be slipping on the drive shaft do do not fully engaging the Woodruff key and causing not enough water flow?
