n36511
I have an issue right now where my Boston Whaler Rage heats up. I can put the boat on a hose in the drive way and it seems to be fine. A stream of water shoots from the back of the boat, very little water is coming from the exhaust ports. Is water ever mixed with the exhaust or does it just circulate around the muffler then exit the port on the back of the jet drive? When I put it in the water here in FL, the alarm goes off within about 5 min and water will boil off of the muffler. I have removed the thermostats completly and that has not changed anything. I tried to remove the screw to view the pressure relief spring and ball in the jet pump housing, but it is seized. Any thoughts? Is the exhaust supposed to be "wet" or is the dry exhaust expected??
As always, thanks for the help!
