n36511
I am currently having a problem starting my engine. I have replaced the battery and the starter. I still have the same symptoms. Try to crank it and it barely turns over (almost like battery is dead). I removed all the plugs and it turns over a little better but still not very strongly. When I attempt to crank, the starter, and the positive and negative wires get really hot. Does this indicate a possible issue with the ground wire? I have attempted to bypass the stator as well and get the same results. Any next steps or pointers would be appreciated.
Thanks,
Scott
Thanks,
Scott
