thomas baines
Last weekend my engine started fine and idled fine, but when I increased throttle it started to go then quickly began to lose power all the way down to stalling. This happened 3 times in a row. I had put older gas in it that day so i changed the fuel filter on the water. After it taking a while to get reprimed it seemed to run slightly better. However it idled much lower. Does this sound like it was just moisture in the gas or something else? also I found a small fuel leak out of the electric primer. Could the problems be connected? thank you for any help
