Friend of mine had a great running 15hp that sat for a couple of years and now it won't run so he gave it to me. I fiddled with it last fall and and got it to fire up a little if I pulled the ignition advance and throttle levers out a little so I though maybe the primary circuit was plugged in the carb.
This spring I tore the carb down and gave it a soak even though it looked great inside, made sure all the passages where clean and put all new parts in it. Put it back together and still wouldn't start. Fiddled with the timing advance lever again and it fired right up and ran great at idle for a minute until it slowed to a stall and now will not start again.
Just to be sure I checked for spark on both cylinders and it seems good and I'm getting 95psi on both. If I pull it to much I get fouled plugs so I know I'm getting gas. Beginning to think I've got some erratic ignition timing. At this point any suggestions would be appreciated. I downloaded the service manual and will start checking components but I'm hoping someone knows of common problems that might cause this.
