DonaldDuck
I've looked everywhere for the rubber stop on the "full spark advance stop screw". Can't find it. Also the timer base has a good bit of travel after the throttle is moved to full open. I wired the timer base as far as it would go and continued the timing sequence. Initially the timing was about 20 degree. I adjusted it to 24 (manual calls for 28).
It worries me that I might be missing something. By the way this is a TJ90TLETS.
Any advise will be appreciated. Thanks
