perrytrails
Just picked up this motor and have a few questions. Didn't get a manual, or book with it. Put it in a trash can and the first pull it started after sitting all winter.
I noticed a small amount of oil had leaked out over the winter from the prop exaust, but had read it is normal. But in the pics you will see oil blew out of the hole behind the motor. I wiped this off and when I started it the second time there was little if any oil.
Motor started easy and ran smooth but I noticed that no water was coming out of the black rubber hose, (I'm assuming this is the pee hose ) so I shut it down. Any suggestions? I just ordered a repair manual for it.
The model number is J10RETM if this is some help.
