93 JOHNSON 40 GEARCASE LUBE QUESTION
P
paul p
Guest
" Hi
Could anyone tell me the
" Hi
Could anyone tell me the gear oil capacity for this motor (93 johnson 40hp twin)?
Also i've identified the drain plug but there appears to be two other plugs in the leg, Which is the correct level plug? (one is just above the gearcase "bullet" and is a posidrive head the other is much higher and has a slotted head same as the drain plug)
Thanks in advance
Paul "
"Paul..... The two identical s
"Paul..... The two identical slotted screws are the fill/drain and oil level plugs. Fill from the bottom until it flows out the top hole.
Joe
" thanks for your help joe, it
" thanks for your help joe, its much appreciated. "
