I have a 1993 25hp Johnson J25RETS on a 2008 Stumpnocker 14' with a brand new 10x13 aluminum Solas prop, rebuilt carb, synch & Link, Joe Reeves timing set (set the timing at 4 degrees less than the factory specified 30 +- 1 degrees, per Joe Reeves method. I set it at 27, because the screw would not go lower than 27. It was at 30 degree when I started the test. In other words it was at 30 degrees before I adjusted it to 27 degrees). Compression is 123 lbs on both cylinders.
Took out the boat this weekend and wide open with 2 adults (425 lbs) and 6 gals of fuel plus two batteries and electric motor and equipment (same or less than both tests below) I get 4400-4500 rpms and 16-19 mph, measured on a GPS.
Creekman at microskiff.com says he gets 30 MPH with the same boat, engine, and weights http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1343782844
The Evinrude Performance reports with 25hp ETEC that weighs like 60lbs more than my engine says it gets 27mph http://www.evinrude.com/Content/Pdf/neutral/performanceReports/PE857.pdf
The engine does not feel like it is running at full power, sometimes it would not rev past 4200 rpms. I had to run near wide open all day to run a round trip distance of like 32 miles.
Will pull plugs tomorrow to look inside and test spark and timing again. Is is possible for the engine to run that fast on just one cylinder?
Any suggestions?
Any suggestions?
