Buck-eye hunter
I have a 93 Johnson 120 that has a miss at idle and will stall at times. I took the boat to the lake and the boat seems to be fine at wide open throttle. So far things I have done are:
1. I did a spark test and have spark at all cylinders that jumps 1/2" on spark tester.
2. Changed Spark plugs.
3. Did a drop test by pulling one plug wire at a time, no change in motor when wire is pulled from #1 can see spark jump between wire and plug when putting wire back on.
4. Marked TDC on the flywheel for all cylinders. Hooked a timing light up and checked timing on each cylinder. When hooked to #1 I do not see #1 I see #3. When hooked to #3 it is showing #3. When hooked to #2 or #4 I see #2 & #4.
I never see a signal or flash for #1.
I do not have a DVA adapter yet to test. Any ideas on what is causing this problem?
