93 johnson 120 HP
doug_k
"I have a 93 18ft four winns w
"I have a 93 18ft four winns with a 120 johnson.
That runs great, while looking under the dash I noticed what looks like a warning buzzer disconnected. I connected it. When I turn the key on it makes a quick beep, like it is telling me it is working. Should I disconnect this or leave it hooked up? Anyone know what this is? I have no temp guage. Could this be the overheat alarm? I would hate to start the boat and something shorts out.
THANKS"
"That is Your audiable alarm!
Reacts on temp: Continuos alarm
No oil (VRO): Short alarm every 3 sec
Low oil (oil tank): short alarm every 30 sec
Ign on: short beep = function test,ok"
"Got another question about th
"Got another question about this motor. Does it have the tell-tale water jet from the top side? I guess some people call it the tattler. On the (looking at the back) right side just under the block, there's a threaded fitting. Tracing the hoses it connects to inside the cover, one goes to the bottom of the block, and the other goes to the top on the other side?
Thanks in advance."
