Hello, first time poster here. Here is the issue:
While prepping the engine( plugs, carb cleaning, fresh gas)for this summer, I started the engine on earmuff water supply. Engine started on first turn of the key...no problems.
Tale tell had steady stream, then I notice water coming out of the driveshaft case where the engine is connected to the transom. I check around the powerhead, no leaks visible from above.
I have never seen this before, on any outboard. My thought is there must be a leak in the water connection somewhere between the waterpump and the engine, and it is filling the driveshaft case.
How does the water get from the lower unit to the top? Hosing or tube?
How does one get into the area to inspect and repair?
Thanks for your advice
Regards
Sam
Regards
Sam
