seaswirl93
"Last week I had an issue with
"Last week I had an issue with the boat. Put it in the water and it cranked over but would not start. It was getting fuel. Finally after 15 minutes it started but ran very rough at low RPM's. Got it up to operating temp. (140) and it ran pretty good for 5 minutes. Stopped for a moment but it would not start back up. Battery did get low after some cranking. Towed it in, got it home, tightened the alternator belt to about 1/4" play and it started right up everything was fine. Today took it out, it started right up ran great for 5 minutes at around 3600 RPM, stopped and it would crank but not start. Checked for fuel, OK, alternator belt seamed to have the right tension, Towed in, got home tightened the alt. belt agian it started right up. Does this sound like an alternator issue, battery issue. I checked the voltage reads for the alternator and they were equal to the battery. What do you think the issue could be?"
