After first cold start up of the day. I warm motor up,put in gear and throttle up to plain out boat. About the time boat plains out,the motor will just die,as if you turned the key off.It will start right back up and run fine for rest of the day.It has does this the last 8 out of 10 times I've had it out.
This motor dose'nt cold start as fast as it used to. Some times I think it's not firing at first,at cold start up.But it will usually start good the rest of day.
I've checked all the connections,grounds,bolts that I could find in the motor and ignition.
Thank you,Tony
Thank you,Tony
