having trouble after running a
having trouble after running at higher rpm the engine starts running rough until rpm are lowered to about 1500-2000 then runs like new read in the manual says eng. has a limp mode and this is what it does if ur having problem with temp or oil press. changed impeller t-stat blew all the water lines out new carb. fuel filter. the oil press. gauge reads good temp running about 160 but the problem still exsists any ideas what else to look for? thanks
