Mbishop412
I have a 1992 5.8 OMC Cobra. I had a fire last year. The solenoid melted, as well at the connection to the starter, and the positive battery terminal. I installed a new starter, new battery, new solenoid, new alternator, and new wiring. After approx 5 hours of normal operating, the solenoid cracked down the middle. The positive wire, to and from the solenoid, were extremely hot. I cannot figure it out. The solenoid is self grounding with a bolt through the motors frame. The only issue I see is the previous owner bypassed an ignition wire. Theres a straight wire from the ignition key to the solenoid. It doesn't not go through the neutral safety switch or harness.
