92 murcury oil inj. black max fouling plugs
bdasbob
i have taken it to the shop and had the oil injection system checked. the tech told me that it was ajusted properly. i have 100 to 105psi on all cyl. i have to change plugs about every 3 tank. oil fouled
Confirm correct plug is being used. Confirm the operation of thermostats and poppit valve.--------------------Check that your ignition system is strong.----A good system will easily fire across a 7/16" gap or better.
NGK BU8H is the right plug for a V6 in those years.
All 6 are fouled? Check the ignition system.
Use the Premuim plus oil and 89 gas.
Check the oil rod adjustment.
Check the 2 PSI valve in the oil line.
