arild_johannessen
Bought myself this engine some weeks ago, and the problem is that the engine suddenly would not accellerate beyond appr.3000 rpm.
It idles smooth,but runs a little bit weak maybe?
Previous owner had it to workshop, they changed fuel-pump,power-pack and rebuildt the carbs,no difference.
He would not spend more money on it, so I bought it,thinking that this problem could be solved, but now I am really
starting to wonder.
I have now done all the DVA-testing like the CDI-troubleshooting says ,using the CDI DVA-adapter,and it seems that
all values are inside spesifications.
Here are the values (cranking): STATOR DVA: low speed 245V(connected) 274V(disconnected)
high speed 52V(connected) 46V(disconnected)
Stator resistance: lowspeed-521 ohm highspeed-27,6 ohm
Trigger DVA : 8,5V connected and 12V disconnected on all 3 cyl. Resistance on all are about 1175 ohm
Powerpack DVA to the coils are about 240V at idle.
Have done carb and ignition sync, set the timing correctly,compression is 112psi-115psi-119psi (1 2 3)
I am lost here,anyone with some good advice here,will be much,much appreciated.
Have tried with the 2 yellow stator wires disconnected,no difference.
starting to wonder.
