B
Brian Throckmorton
Guest
"my trim switch mounted on bow
"my trim switch mounted on bow of boat does not work , trim switch on throttle also isnot working , the trim switch on the motor only works in down mode ,nothing in up. I checked power at solonoid box and both are getting power . do you think a switch is bad ? or could it be somthing else . thanks brian
p.s this unit was working fine when i put it up over winter."
