92 40hp Johnson wont idle.
jmredwine
I've got a 1992 40hp Johnson. So here's the problem... it won't idle for more than a cooked minutes without choking down and turning off. It does this in reverse and in slower speeds as well, and takes a while to start up. It runs fine at higher speeds. It doesn't really sputtered or anything, just cuts off. Had the same issue last year, and I sped the idle up a little, which seemed to fix it for a while, butbow its doing it again so what could be causing this?
Thanks!
