FlyingCrest
Recently acquired 40hp 92 johnson, PO was running with VRO hooked up. I left as is, but have been running with 50:1 for a couple of tanks just in case while I verify oil level in tank dropping. It is dropping a noticeable amount.
I went to put it away for the season, and decided to check VRO warning horn so, I disconnected VRO line to see if warning horn would sound. Nothing after 10min of idling in tank. Didn't have time to fiddle with it, so put it to bed for winter.
Next day when I had time, checked manual and it says to verify purple VRO D wire has battery voltage with motor running as next step if no horn condition...but now it's winterized, so can't check with running, but thought I would at least check the wire connections are correct.
Found 4 pin female connector coming from VRO with black, tan, gray, purple wires. It plugs into 4 pin male connector, but the purple wire is snipped as it exits the male connector, so goes nowhere? Could this be my problem with warning horn? Can anyone explain what the black, tan, gray, and purple wires are for so I can verify it is wired right. I know powerhead was rebuilt by PO, so maybe something is wrong with wiring for horn.
