92 115hp Mariner No Spark
samm835
"Well I haven't been able
"Well I haven't been able to get any spark. After getting some advice, I think the problem might be the trigger and stator. I am not definitly sure, but I guess I need to get it towed to the boat ramp and then trailer it to an actual boat doctor. Before I do that, maybe you guys can try to help me make sure I narrow down my issues and try to keep the cost at a minimum once its at the boat DR. So here is what I have tested and what it is doing. 1) Motor will turn over 2) It is getting fuel 3) I disconnected the black and yellow wire on the switch panel, I believe this will over ride any safety switch it has and I still am not getting any spark to make it fire up. I think there was a couple of other things I tried but for some reason I am forgetting right now. Can anyone think of anything else I should look at prior to taking it out and having the DR look it over? The only good thing is that it is towards the end of the season. Thanks for any help."
Have you checked the Safety Sw
Have you checked the Safety Switch ?
No spark on ALL Cylinders?
How did you check for spark?
