Recently I've inherited a 1991 Mercury 9.9. It had been sitting for about 10 years without being started. I bought a carburetor rebuild kit and rebuilt it. I used a ton of carb cleaner and I carefully blew out all the passageways. I also made sure the jet was clean and perfectly clear. The engine starts now and pees but dies after about 2 minutes. I inspected the float and needle valve and they are in good condition. I'm starting to suspect my fuel line and connections. when I'm priming it (squeezing the bulb), is it normal to see a few drops of gas leak between the engine connector and the hose connector? It drips into the cowling when I'm squeezing. Also, should the fuel filter always be completely full to the top? I've noticed the engine quits when it gets down to about 3/4 full. The send and receive ports are at the top of the fuel filter unit. I'm curious how can it get gas if it isn't completely full all the time.
More info: I bought a new gas tank and I'm using fresh gas @ 50:1.
Thanks!
Thanks!
