slowmocomotion
Hello,
I have discovered this forum while searching for an answer to a perplexing phenomenon I am experiencing with my newly acquired boat.
I am completely green to boating and just purchased a 1994 Lund Angler Deluxe with a 75 hp mercury outboard. I was thoroughly going through the boat and motor in my drive way and I came across this problem.
When I turn the key the starter pops up, engages the flywheel and then proceeds to spin and turn the motor over to start with no problem.
When I hit up or down on tilt/trim the motor moves up and down respectively. The problem is that when I hit up or down on the tilt/trim the starter also engages the flywheel simultaneously. Once engage the starter only spins the motor/flywheel by about 10 degrees. It does not spin the flywheel much, no matter how long i hold up or down, but I did not think the starter was supposed to touch the flywheel while tilt/trim is being operated. To make it clear. When hitting up or down on tilt the motor does not spin like it would when I am starting it only moves the flywheel by an inch if that.
Please help explain if this is normal.
