papafrancisco
I got gutsy today and replaced the water pump that hadn't been changed in over 5 years. In removing the lower unit, I read the forum as to how to discoonect the shift rod by pulling the hair pin and pushing the lever. I now have the lower unit back in place however I don't believe it is correct. Before I installed the lower unit I ensure I could rotate the prop shaft freely in both directions. Now when I rotate the prop either direction, I can feel and hear the pistons moving. The shift rod is offset at the top. Is there a certain position the shift rod needs to be located when re-installing the lower unit?
