91 DT 200 Suzuki Exante
C
Chuck Worth
Guest
"When engine is cold it runs g
"When engine is cold it runs good, after 20 minutes and its warmed up there is no mid speed, it only will run at idle or run wide open, some times you can get that mid speed then it either takes off or idles back down to idle without ever touching throttle within a few seconds, and sometimes stalls when idling, any ideas?.... Thanks Chuck"
"Update: I rebuilt fuel pumps
"Update: I rebuilt fuel pumps and water tested, seems to run better, you can somewhat go a little faster than idle speed unlike before, but still seems to just run away without touching throttle, I also forgot to mention that throttle valve sensor was replace a while back thinking it would fix problem but it did not, the throttle valve is adjustable and I didn't know where to put it, I basically put it in same position where old one was, any ideas how to fix runaway problem?? thanks again Chuck.."
