91 90 HP Force Power Trim Problem
edc
My relay based trim unit will
My relay based trim unit will go up or down but not both. Have switched clicking relay with new but have same problem. Have switched various combinations of the three relays with same issue. New relay is same Mfg. (BOSH) but different part no.
Should I replace both??
HELP-HELP-HELP-----TOTALLY CONFUSED LOCAL MECH.
now u need to test for voltage
now u need to test for voltage to and from the relays to motor
sounds like bad motor
replace BOTH relays. these cur
replace BOTH relays. these curcuits are strange. they backfeed thru opposite relay. both relays are involved in both directions. You may still have a bad one.
they are grounded through the
they are grounded through the opposite relay
u will get up or down usually when one is bad
but they are clicking so it is wiring to the motor
DO NOT PUT GREASE ON THE RELAYS ALSO
"Want to thank all contributor
"Want to thank all contributors. System worked after replacing both relays. Did test voltage on old ones and found good. Checked ground wires too. Found new part had minor difference in part no. Motors now put to bed for, hopefully, short winter after replacing lower unit lube and fogging cylinders.
Thanks again!"
