papafrancisco
I read MANY posts on the subject and have gotten a lot of good information. Problem: The motor eventually will start at WOT. I no longer engage the primer solenoid when starting however I do engage the ignition primer switch three times. My question is where should the throttle be for a normal start? When I push the throttle forward (when starting), there is a dead zone before there is any rersistance. With the motor shroud removed, I noticed the linkage does not move until I get past this dead zone. Is this the motor idle zone? Should the motor start in the idle zone or with more throttle? I also noticed the linkage does open the butterflies until closer to WOT. I noticed the large black plastic cam is not in contact with the small black dowell for engaging the butterflies. The arrow on the cam does line up with the aforementioned black dowell however if does not contact the large cam. Should the cam contact the black roller dowell when throttle is at home position? BTW the primer solenoid is in auto/normal position. The primer solenoid was checked by removing the hoses to carbs and the switch engaged. Solid gas flow from both ports.
