DouglasinAustin
Friend bought a "lake ready" '91 Ski Nautique with a 5.8l PCM motor, carb. Not lake ready. After 5 min water temp was 220+. Shut it down. Found impeller worst I ever saw. Hub separated from fins. Replaced entire raw water pump new. Thermostat (160F) was rusted closed so replaced that. Inspected lines and ports for impeller debris, and found none. Running in driveway (idle and <1000rpm with hose direct connected to hose leading to raw water pump. After a minute temp crept up to 180, 190+, so I shut it off. Exhaust manifolds are nice and cold and water is exiting exhaust pipe in back. Engine water pump is not leaking anywhere. So the question is, could rust buildup in block, heads, or other blockage in intake manifold cause this? Also, I've worked at Mastercraft and Correct Craft dealers for a few years, and never heard what the CC parts guy said when asking about new thermostat. He asked if I'd be running it on Lake Austin (65-70F water temp) or Lake Travis (~90F). Said he runs 160 on colder lake and 143 on warmer lake. I thought the thermostat would keep the motor at the proper engine temp, and that the temp of the water was irrelevant. And I'd never heard of this. Does this sound right? And would running garden hose pressure, even if it's high, be an issue because it's not enough water? I don't remember this in the 35 yrs I've been flushing my motors, but maybe I haven't been paying attention. thanks!
