bassmaster59
Took a break from trying to get my motor working the way it used to. Am going to have another go at it. I found some adjustments in linc & sync, & timing pointer that were set wrong ( according to omc fac. man.) by the guys at the shop I took it to. I now need to set my timing the dselbee way & not sure I know how to discon. the quickstart. I just would like for someone to verify the proper procedure to disconnect quickstart on my motor. Unplug the yel./red wire from the selo. to the pp, unplug the black wire from the pp to the engine harness, & ground the black wire from the pp to the eng. block. Is this all & is it correct? thanks, jeff
