nickhaulotte
I recently rebuilt my 95 90 hp force. I honed the block placed new pistons,rings,wristpins, retainers,roller cages,seals, impellar, carbs rebuilt. After completion we broke it in with a 25-1 mix for the first ten hrs. Yesteday I took it out on the water and ran great for half the day until the conn rod broke on the middle cyl and drove itself through the block and intake man. When I got it home I took the head off to look at the inside ( curosity) and found a couple needle bearings and the bolt the connects the rod to crank boken in the intake port. My question is.... Is there something I may have done wrong during the rebuild? I placed everything in to specs, as far as lb placed on the bolts.
