M
Matthew Quintal
Guest
"2001 Boston whaler, 90hp merc
"2001 Boston whaler, 90hp merc. will not Start. when turning the ignition key, it will not turn over, motor just clicks. Battery is good, all gauges work when key is engaged. the motor will turn over intermittenly, but will not start. This started this fall while out fishing however, after 1 or 2 trys the turn of the key would turn the engine over and start. The boat has sat for a few weeks now, and the problem has got worse, whereas, the boat will not start, and 1 out of every 100 turns of the key will even turn it over. Does this sound like the starter? NEED HELP, more snow is on the way."
