I have a 2005 2-stroke Mercury 90hp, and need to know the location of the low speed adjustment screw on the carb? A picture would be helpful. I am not a boat engine mechanic, but have a slight bogging situation when i'm easing into the throttle on my boat. It will bog slightly, but if you feather the throttle a bit and ease into it everything works fine. Mostly noticeable when loading the trailer, once you're on the bunks and you put a load on the motor to slide it up further, it will bog and cut off... unless you utilize this feathering of the throttle. Other than that, the engine runs flawless... Can someone help me out? Thanks in advance. hvychev77
