90hp fuel issues after an hour out
Bdunbar
So her is what has happened recently.
I took out my boat after getting it ready for the season, noticed that the float Bowl vaporizer cover had leaked fuel when I primed it. Took the boat out ran fine for about an hour and a bit, then when cruising along it felt like it was running out of fuel surging finally dead. Would not start, use the trolling motor for about 15 minutes, main motor started again. Ran for about 5 minutes and again same symptoms.
Brought the boat home started in the driveway no problem ran fine idled up. Replace the complete pump mixer vro system with one I had as a spare. Took the boat out the next day same issue. Brought it home started out right away ran it for a bit, then we're done start again, sprayed fuel into all four carburetors while cranking it and it fired up.
I am wondering if I have an issue with the pump, possible vent line plugged which I will check these tomorrow. Not 100% sure how the pump works, if it is off pulse limiter.
Any advice would be greatly appreciated.
