90hp 93 mercury outboad trouble running
E
errol durbin
Guest
"new trigger or whatever year
"new trigger or whatever year before last... at a idle speed it would die..... replace spark plugs, fuel pump. now at 3000 rpms it runs pretty good but at 3500 or above it will rev up a little and then die..... any guesses about what the problem might be. has 450 hours tt..... errol"
"sonds like maybe a carb probl
"sonds like maybe a carb problem,try cleaning them out,problem is different then last year?If so,I would try that,does it idle?or does it stall out?it sounds like your running out of fuel,anybody else?a little help?"
Reeds worn? That is a lot of h
Reeds worn? That is a lot of hours depending on how it is used. Comperssion check?
