Hello,
I’m at a loose end with my 90hp tohatsu TLDI, when I turn the engine on I have 3 lights flashing, the engine will start but keeps flashing. When I go into the diagnostics it tells me that the TPS 2 idle Position incorrect.
What I have done,
New 1000cca battery
set the TPS numerous times following the manual as getting the correct beeps
checked the TPS readings (all seem within tolerance) with a multimeter
checked the wires for the TPS to ECU for continuity
Does anyone have an idea or am I missing something. Looking at buying a new TPS sensor.
Thank you
Perry
What I have done,
New 1000cca battery
Thank you
Perry
